Brookes Web Site
Date:  9-13-2010
Number of Hours:  9.50
Manual Reference:  7.7.3
Brief Description:  Gear socket install, relief forms for fuel dump an
Tweaked main gear overcenter mechanism, trimmed area around sockets to insure freedom of movement of cables. Made sure wheels, overcenter linkage, and airplane was level. Checked tension of over center so that spring engaged overcenter with no additional force. Tacked gear sockets in with cabo/flox. Will glass in after gear is finally adjusted..
Made relief layups for the hydraulic dump valve as well as the fuel shutoff control using 3 bid.
Wet sanded nose gear leg and fork.
Sockets epoxied in
Sockets epoxied in
Dump valve relief curing
fuel shutoff relief curing
Copyright © 2001-2018 Matronics. All Rights Reserved.
