Brookes Web Site
Date:  5-21-2010
Number of Hours:  7.00
Manual Reference:  6.6.2
Brief Description:  Panel
Continued to fit and shape panel. Decided not to provide separate "subpanels" for throttles. After discussions with Jason of Aerotronics, will let Aerotronics provide for the T/P/M installation. Extended the mid support of the panel with 11 Bid and a Scharf joint. Reinforced the bottom of the panel with 1 x 3/16 aluminum stock. Attached with epoxy/flox/cabo mixture. Marked hard points for pilot seat per manual instructions. More analysis to be done to determine location.
Bondoed in a wooden support inside of leading tip of strakes over doors in order to allow it to maintain it's shape after cutting off (in the future).
Aluminum reinforcement
Extending mid support
Marking Pilot side front seats
Copyright © 2001-2018 Matronics. All Rights Reserved.
