Brookes Web Site
Date:  1-4-2010
Number of Hours:  4.50
Manual Reference:  9.2.5
Brief Description:  Adhere Lower Strake to Main Spar
Did final fitting for lower strake. Set up an I beam under trailing edge to act as a clamp securing aft edge of strake to Main Spar. When all was set up, Scott and I used Structural Adhesive and Flox to attach strake to spar. Due to low temperatures and forcast lows for the night, we put an 60 watt incandescant bulb over lower strake and covered the the strake area with the upper strake and blankets for heating to promote curing. .1.5-2
Copyright © 2001-2018 Matronics. All Rights Reserved.
