Brookes Web Site
Date:  12-1-2009
Number of Hours:  7.00
Manual Reference:  5.0
Brief Description:  Fit Doors
Trimming doors was not sufficient to get them to fit rignt under the load of the gas spring. Did several iterations of shimming hinges attempting to get doors to close without rubbing. In spite of a lot of shims could not get doors to close properly. Have to come up with another solution as the shims caused such a misfit of door/fuselage that it would be difficult or imposible to do sufficient body work to fair them up. Jeff C. thought the gas springs were too strong. Researched other springs. The ones installed are 49# springs. Ken B. found the same spring with a 34# strengh. Ordered those springs. Doors on hold for a while
