Brookes Web Site
Date:  10-29-2008
Number of Hours:  8.00
Manual Reference:  7.6.1
Brief Description:  Mount MG pulleys
Fabricated Aluminum plate. Shaped pulley holes in gear bulkhead. Drilled and mounted aluminum plate. Fitted pulley holders and aluminum angle. Mounted aluminum angle into its proper position a little off the floor so that the vertical sides of the aluminum plate and aluminum angle would be parallel. Secured aluminum angle to floor with thick mixture of structural adhesive and flox as well as 2 pop rivets.
Aluminum plate
Aluminum plate
Pulley holes
Pulley holes
Structural adhesive curing
Copyright © 2001-2018 Matronics. All Rights Reserved.
