Brookes Web Site
Date:  9-25-2007
Manual Reference:  6A.1.4
Brief Description:  Install lower Aileron torque tube
Worked on control system by installing bearing supports and bel-cranks into the keel hardpoints, then installing the dreop down portion of the push rod then back to the assembly at the rear of the keel that holds the trim motor and rear bearing support.
Copyright © 2001-2018 Matronics. All Rights Reserved.
