Brief Description: Fuselage Bottom Layups - Clean up
I removed the peel-ply from the floor layups. I they used some 80 grit on a soft pad and sanded some of the peel-ply edges down. The layup came out nice. There were just a couple small delams that developed. One on the edge where the IP will bond to it and a couple at the back edge of the front seat pocket. Both of these areas will have additonal BID tapes added to connect the Seat Back and IP to the floor. I sanded these delams flat and will drill and fill the voids with resin.
