Brief Description: FWD Seat Back Tapes - Bottom Foam Prep
Installed the last BID tapes to the backside of the FWD seatback bulkhead. Pre-pregged tapes then peel plyed. I also cut down the fuselage bottom foam to basic size and joined the resulting two pieces with micro. I used wood blocks and wedges on my flat table to apply clamping pressure to the joint.
