Brief Description: Prepared for LG Extrusion 15 Ply Layups
Spent some time studying the plans and drawing A5. I then marked out the locations for the 15 ply BID pads that will be under the landing gear extrusions. I also marked off some ply drop off lines to hopefully have a nice taper from the pads to the surface below. We will see how I do! Then I cut up some strips of BID from my scrap BID bin that I will use to make the layups on another day. I also made some poster board ply patterns to use to cut the plys to final size
Sharpie marks for pads. Drop off lines can be seen as well as the centerlines where the extrusions go
