Removed weight from aft foam insert and block sanded it flush to the wood pieces. I then cut all the UNI for the RH fuselage inner skin an the UNI for the upper longeron reinforcement. Cleaned up a bit!
Foam after sanding flush to LWX, LWY, and lower longeron
