Brief Description: Upper RH longeron and doubler glue up
I decided to glue up the RH upper longeron and upper longeron doubler together now to ease the bonding task and clamping when bonding it to the fuselage side. While marking the doubler position on thr RH longeron I measure the LH one just to be sure. I figured out that I bonded the doubler one inch farther aft than plans on the LH longeron. Woops! Hopefully that won't cause an downstream issues. The correct dim is 34.75" from the front edge!
