Brief Description: Instrument Panel - aft layups (the side you see)
I made the two ply bid layups on the cockpit side of the instrument panel. First I inserted the 1 x 2 inch 1/4 inch thick plywood reinforcement that will be used to mount the fuel shut off valve. I installed this with thick micro. Then I added the third ply over the top half of the IP. I peel plyed the entire layup for cosmetic reasons.
