Install rudder pedal push rods, bolts facing inboard Adjust push roads to set pedal @ 7.25" from firewall Torque to 50-70 ft lbs Test travel - insufficient clearance w/ torque tube end plate Reverse nearest push rod bolt, replace w/ shorter bolt to allow intertion through end plate access hole.
Connect rudder linkage cables to torque tubes, torque to 44 lbs Assess rudder travel, inital alignment Inspect linkage pass through at wing spar box Adjust cable tension after clamping cable, balance to center rudder Use cable tension meter to set at a 22 setting for caliber 1 cable
