Assemble aileron push rods - locking nut - large adn small bearing Install aileron push rod onto bell crank - adjust to length
install pilot side aileron set 2 hinges using needle probe insert bolt in center hinge, secure insert bolt in inboad hinge, secure insert bolt in outboard hinge, secure
attempt install of copilot aileron unable to achieve alignment sight wing hinges, check OK sight aileron hinges, out of alignment Gus to refer to original installer
