Brief Description: Installing Flap Brackets and Fittings
24. Install and Rig Flap
Flap assembly Flap torque tube fork Insert bearings, castle nut on torque tube fork Bore out cotter pin hole Insert cotter pin, bend back tines to secure
Caliper width of support welded bracket Cut femalic bushing to length with band saw based on measurement Sand, bevel cut bushing Insert bushing into bracket use 3-fingered hone to auger out bushing to fit flap torque tube
at airplane test fit bracket, bore out holes slightly to fit insert outboard torque tubes into wing bushing insert counter torque tube into backet
install bracket/tube assy onto studs secure bracket w/ 12 counter-sunk screws and tennerman washers inside. torque to 40" lbs
