Edwards Web Site
Date:  8-18-2021
Number of Hours:  9.00
Brief Description:  Fitting the canopy to the frame
Started to fit the canopy to the canopy frame, Had to install and remove several times to trim the rear edge and chamfer the lower front edge. It fits very well. Carefully drilled all of the attach holes to #40. It is now ready to be removed again to enlarge the screw holes and machine countersink for #6 screws.
Front section of canopy
Raised position
Raised position
Clecoed then drilled for canopy mounting screws
