Continued assembly of elevators. Glued the foam spars in the the fixed side of the left elevator. Tank sealant takes a while to set up. Riveted hinge to the elevator trim tab. Put together the electrical connector for the elevator trim tab and mounted the servo to the access panel and installed in left elevator. Started deburring parts for the tailcone.
