Fabricated and installed the air intake snorkle. I had to heat up the section under the starter and reshape it slightly so thst it would not be in contact with the starter. I used a heat gun and pressed a piece of 2" diameter PVC pipe into the heated section in order to add a slight bend near the contact point.
