Brief Description: Unboxed engine and prepared for mounting
Unboxed the engine and lifted with engine hoist to do prep work for mounting to the fuselage. Drained the preservative oil and added desicant tubes to the bottom spark plug holes. Installed the ignition coil mounting brackets over the magneto mounting sockets. Installed the prop govener. Installed misc. pipe fittings called out in plans.
