Brief Description: Joined 2 parts of lower fuselage
Deburred and primed the parts to attach the rear part of the lower mid fuselage to the firewall part of the lower mid fuselage. Drilled all the holes in the machined pieces where the spars meet up and installed the main bolts that hold the spars together. Clecoed all the holes where the two skin section overlap beneath the spars and turned the assembly on its side. Ready for riveting.
I need to take a timeout to clean up and make more room in my garage before continuing...
