Edwards Web Site
Date:  1-25-2020
Number of Hours:  6.00
Brief Description:  Added tank baffle to right wing tank
Finished leak testing the tanks with water before adding the back tank baffles which would make it impossible to seal any leaks from the inside. No leaks! Added the baffle to the right tank. Made sure there was a lot of sealant along the edges and corners. I still need to finish a few of the rivets along the side and the Z-attach brackets, but will wait a couple of days for the sealant to set up.
Baffle side rivets in place
Closer view
Closer view
Outside view
Outside view
