Brief Description: Front spar-match drill splice/reinforcement angels
Per the instructions I matched drilled the HS-702 from spar channels to the HS-810-1 reinforcement angel and the HS 814-1 splice angle inbard of the bend lines.
I also marked the 810 and 814 whree the taper starts 3-3/8" from the ends.
