Brief Description: Routing throttle and fuel shutoff cables
If you follow the Van's instructions in order, you'd probably have the tailcone assembly mated by the time you reach this step, which is why it's a good idea to listen to the people who say wait until the last possible time to do that. I can't imagine stringing and connecting the fuel shutoff cutoff cable if you had to crawl back through the baggage area or if you had to work through inspection panels.
But that got done, although the amount of extra cable I have after the connection at the shutoff is made appears to be less than what the plans show so I want to ask Van's about that.
I also threaded the throttle cable to connect it to the standoff on the engine. I routed it as best I could. I still really would like that service bulletin replacement for the top engine mount standoff so I can clamp everything down.
