Brief Description: Preparing to drill side hinges to top cowling
I had to go to the hangar to clean and dispatch the camper to a renter for the weekend so I did a little work on the cowling. Notching a cutout for the hinge pin tabs in the top cowling. I don't really like the look of this because you have to take a pretty good size notch out of the top canopy to be able to pull the pin straight out. But I did it. Whatever. I didn't want a Bronze Lindy anyway.
Then I measured 9/16" up from the bottom of the top cowling to mark rivet holes for the top hinge, removed the cowling and drilled the holes in the cowling, then put it back on.
I decided to match drill into the hinge material on another day.
