Brief Description: Started working on flap mechanism
Separated and primed parts and then riveted bearing housing to each. The plans only call out specifically one rod end bearing on the flap push tube so I stopped to hear from Van's support on which part number goes in the other end of the threaded tube.
(Update: The other end is connected to a rod end bearing that is already welded to the flap mechanism. )
