Brief Description: Completed mating of forward and mid fuselage
I gave up on trying to get the forward fuselage mated with the fuse assembly turned upside down,so I carried it -- yeah, you can carry an RV-12 fuselage -- over to the rolling workbench and put it right side up. It went together nicely after that.
The trick, I learned on VAF, is the mid fuselage skin has to "sandwich" in between those "ribs" and the forward fuselage skin.
Then it was on to Section 23 where I discovered the pre-bent twists in the longerons was made in the rear, not the front of them.
