BOB'S WEB SITE
Date:  8-13-2017
Number of Hours:  1.50
Manual Reference:  Sectionn 40
Brief Description:  Cut access hole in left wing for outboard light
Not much to do while I wait for a few replacement parts to show up (maybe by early next week) so I cut the access hole for the outboard strobe/position lights in the right wing using the template. Use the hole saw for the radius of corners, then my Dad's Dremel with a cutoff wheel, then shaped it with a sanding wheel in the Dremel, finished it up by sanding by hand and then shot some primer.
I cut the fiberglass light cover to the scribe line but I need to consult a few builder sites because the scribe line-- if there is one -- isn't quite clear to me on the outboard edge.
Also, the only holes where there isn't a mark in the fiberglass to indicate where a hole should go are the three holes where the rivets are already removed in the wingtip cover. Not sure why that is.
