Bent the handle and riveted to the spar, Riveted the rear rib on than riveted on the aft and forward wing tip skins. I added the outboard aft rib and then fluted the forward compound curved rib and riveted.
Then I cut out the template for the nav/recognition light access hole and made the cut and smoothed it all down.
