Brief Description: Started with the bottom center skin (left)
Mostly just prep work. Deburred the edges and rounded the corners. Used the edge bending tool so that it will lie flatter when riveted.Shot a line of primer on the rivet lines, then used the soldering iron to remove the plastic around the rivet holes and clecoed in place.
Ran one set of rivets on the forward section and called it a night.
