BOB'S WEB SITE
Date:  3-28-2017
Brief Description:  Completed empennage kit
I assembled all the components for the AST to trim servo but had to finagle a few things. The spacers I made for the big bolt on the unit were too small so I made that. And I'm going to have to switch to a longer bolt because the whole for the castle nut isn't appropriate.
A couple of the wire pins fell out so I carefully put them back in but I'm still not at all happy with the connectors used here and will be switching to DSUBs after it gets its airworthiness certificate.
Meanwhile, I drove down to SteinAir (they do the parts) for some extra pins and a connector.
I decided there's no real reason to disassemble all of this since I'm building an empty hangar. So at some point soon I'll go back over all the bolts and make sure they're torqued correctly.
Then I'll do some polishing!
