With the time change, I decided to get up early and get to the hangar before the house woke up and get some work done.
I prepped the left side skin and clecoed it in place, then ran the wires for the trim and secured with tie wraps.
Then it was on to the static system. Installed the rivets for the static ports and drove out both mandrels, ran plastic line to a tee, and then installed the static line over the 1/8" clear plastic for the tee. I secured the right side tie wraps but left the left side loose per the instructions.
I ran the string for the control cables but the illustration on the instructions is really bad for routing so I have to double-check that before buttoning the tail cone up.
One note: I did NOT fillet the blue RTV (never use red RTV with aluminum, by the way) because I didn't have any and didn't feel like going to the hardware store. I'll do that tomorrow because today I ran out of time.
