I finally remembered to pick up a 1/4" drill bit from the hardware store so I could drill the tie-down bracket via the template.The hole is used as the inside radius of the bottom of the bracket. So whipped that up with some bandsaw and file action and it came out sweet. I'm so much more focused on quality building than I was with the 7A.
Let me explain that: I was focused on quality building on the 7A project, obviously, it was an extremely well-built machine. But this time I'm more of a perfectionist.
I mean, geez, it's just a tie-down bracket and as sweet as it looks, nobody will ever see it because it's hidden in the most aft part of the fuselage, out of site.
So why make it look like a piece of Swiss engineering?
