Brief Description: Installed oil lines and Adel clamps
Careful review of the plans revealed the path for the oil line to take from the left side of the engine back and around to the oil tank so snaked that through and torqued it down.
Then it was a matter of putting on two Adel clamps to hold the right side oil lines in place, which shouldn't take three hours to do but I buttoned down one line before reading the next paragraph which said a wire needs to also go under the Adel clamp. Of course, it was impossible to take off the screw/locknut without stripping the god damned 10R7 screws that Van's uses instead of a simple AN3-5 bolt. I ended up cutting the nut off with a Dremel, tossing the DG14 and reinstalling it.
I also installed the clamp for the front oil line.
