With the RTV cured, I mounted the overflow bottle onto the firewall after attaching the two hoses, one a breather tube which I routed down to the right side exit and zip tied in two locations. Seems like it needs another clamp somewhere. I attached the rubber line using a hose clamp (I lost the second hose clamp last week when it went flying elsewhere in the hangar. It has not shown up yet. Ordered more) and routed it around the air box to the expansion tank but can't clamp it yet.
I dug out the air filter and assembled that with the scat tubing. I need to cut hinges for the vents but my bandsaw blade is dull from using it to cut rubber hoses so I've ordered a new blade.
The aluminum bushing I couldn't find for the throttle tension wheel arrived. Yep, it was the same one that I'd found in another bag. But I ordered a new one just in case it wasn't.
