I had made a mistake on the heat cable bracket, at least on the pilot side, by drilling both holes out to #30 instead of just the top one. So it flopped off when I riveted it. A new bracket was procurred from Van's and In riveted it in place. Then I ran the cable, which was a pain in the neck because I had to squeeze in under the soon to be instrument panel.
I only had one cotter pin, which was installed on the pilot side so I have to order one -- nickel and diming yself.
I also need to tighten the set screw on the passenger side.
Eric Rushing at Van's, meanwhile, clarified where the oil temperature sensor wire is, which is mentioned in the instructions for routing the hose from the overflow bottle to the expansion tank. So I was able to secure that hose in two places.
The clamps order came in so that hose was clamped to the expansion tank.
