Brief Description: Drilled spinner to forward spinner bulkhead
I reviewed the updated Section 5.18 in the instructions on drilling matched holes in opaque fiberglass. It was pretty detailed and I went with most of it except for tapping the pilot holes. And, of course, I haven't added any fiberglass and flox to the inside, at least not yet.
I used the plastic washers to mark the hole locations then drilled one hole which appeared to be dead on. Then I reinstalled the spinner, checked to be sure it was centered, and drilled the other three holes.
Really only one hole revealed a slight indentation that that the magnet wasn't completely centered but it was completely marginal and no factor.
The sanding I did to the scribe line has allowed the spinner to line up almost perfectly with the back spinner plate. There is a slight amount of aluminum showing but I think that's only because I haven't filed the edges to get rid of the tooling marks. I'll do that next.
