Not much detail to provide here. I basically followed the instructions. Riveted heat dams inside the muff. Clamped an aluminum slider around the muffler, knocked the sharp corners off the relief cuts in the heat muff brackets and bolted them on. Then wrestled with two large worm clamps after placing the heat muff around the brackets. Next step is to bolt them onto the engine but I have to order a stud nut since one was missing when the engine arrived. I found it in the crate, put it aside, and now can't find it. Because: of course.
