Brief Description: Finished pitot tube routing, started on spinner
I looked over the plans a million times and finally was able to get the pitot line routed under the intake plenum, at least enough to keep the connection to the pitot tube relatively straight. I still wouldn't mind putting an Adel clamp in there somewhere at some point.
I covered the end to keep any debris from getting inside as the rest is included in the avionics kit which I won't order until there's a new tax year.
I started on spinner, cutting the aft portion to almost the scribe line and then sanding the rest.
