BOB'S WEB SITE
Date:  10-31-2020
Number of Hours:  0.20
Manual Reference:  SD-00001
Brief Description:  Fully finished SD-00001 service bulletin
Cut off the old connector on the wiring that comes down the tail cone. For some reason they used two white wires for power wires so I did a continuity check and identified one wire, and took a magic marker to it. This will be the gray/black wire and installed it in pin 5. Also marked it at the foreward location.
