Van's confirmed that the torque value for the engine mount bolts is 160-190. I found about 30 inch pounds friction torque so torqued to 210 inch pounds. With the crowsfoot adaptor, that value had to be recaluclated to 190 inch pounds. I attached two fuel lines but couldn't torque them down because my 11/16" crowsfoot is missing and I want to doublecheck that those get torqued down to the steel fitting values on the engine side, which is over 200 inch pounds.
