Brief Description: Set breakout force on nosewheel
Removed the wheel, set breakout force on the assembly to about 18 pounds (it moved one way easier than the other), drilled the axle, installed a cotter pin, and reinstalled the tire. Tire nut tightened to 185 inch pounds.
