BOB'S WEB SITE
Date:  4-26-2018
Number of Hours:  4.00
Manual Reference:  Section 24
Brief Description:  Rear bulkhead
(Multiple sessions). After installing the rollbar and support pieces, I turned to the rear bulkhead and drilled the holes in the bottom flanges on the tail, then prepped the bulkhead pieces, adding supports for the fuel pump bracket assembly. Then I fit them with the fuselage and added the nutplates. Buggered up one rivet hole but drilled out and replaced.
