First, on that screw/nut combination, I threw out both the screw and the nut and started with new hardware and it worked fine.
Today I riveted together various brackets, including the set belt bracket on one side, then riveted various assemblies to two ribs, including the flaperon mixture bracket (whatever that is) and a seat belt bracket.
-13 weather. Perfect for building metal airplanes!
