I started riveting the right floor but couldn't figure out the best way to use the squeezer as the floor interferes with the squezer. If you put the shoip head the aft side, you risk getting smileys. It's less of a problem if you put it on the forward side, but if you ever need to drill the heads off the rivets, that's going to be difficult. Will wait to complete the task until I ask more
