Brief Description: Fit center section to bottom skin
I deburred the bottom skin and then set the clamped center section on top of it and clecoed all the holes along the bottom. More of a pain in the neck than anything else; I clecoed the outboard holes and then set it atop several 2x4's and then reached under to do the remaining holes. Then the instructions say to remove the spring clamps, let the unit adjust itself, and add c-clamps.
I'd already used c-clamps, but, whatever.
Then the instructions say remove all the clecos. I don't think so. I think I'll just keep everything where it is while match drill holes in the forward part of the center section to the big honking angle.
I pulled out my clear plastic housing for the drill bushings, which I've only used once since I bought it 16 years ago (and then I only used it for a couple of seconds while I realized how worthless it was for getting a straight drill shot in the rear spar doubler when setting the incidence on the the RV-7A wings years ago.
Time took its toll on plastic -- as it usual does -- and it pretty much disintegrated when unscrewed the #10 drill bushing that's been sitting in it for the last 10 years or so.
So I'll just flip the drill bushing around and hold it against the hole as I drill.
