Second verse, same as the first. I did try something new to try to prevent enlarging holes in the outboard nose skin when drilling the counterbalance pipe. I drilled to a #40, then removed everything and used the drill press to #30 in the pipe, then clecoed the skin back on and final drilled through the skin as #30. It was better than the left side (I ordered a new skin solely because I didn't like the enlarged holes. The outboard holes are still enlarged but I'll live with it.
