I dug out the flaperon spar and deburred it, then did the same with two outboard ribs that hold the counterbalance pipe, clecoed, then wrapped the skin on and drilled two holes in the pipe.
Removed, spun the pipe 180 degrees and riveted the ribs.
Then I sprayed primer inside the pipe and swirled it around and left it for the night.
