I used the vice, a 7/8" socket set, and a 9/16" socket set to install bearings in both flaperon hinge bracket center sections, then riveted the unit after it was sandwiched by the assembly.
The two countersunk holes on both sides is interesting. I suspect this is intended to basically be a double flush rivet.
