Brief Description: Bottom Cowling Close Out C/W....
Removed bottom cowling & drilled the screw holes that are used to secure the cowling to the closeout. Enlarged close out screw holes to #19 & attached 12ea K1000-08 nut plates.
Riveted the bottom cowl support bracket to the close out plate which bolts to the tunnel angle.
