Jameson & I installed the sniffle (fuel) drain valve & hoses. Routed the outflow hose into the fuselage tunnel per section 49 of the plans. Currently awaiting the delivery of an oil quick drain valve from Aircraft Spruce. Once received, I will drain the preservative oil from the engine & install the valve; then service the engine mineral oil per Lycoming's recommendation.
